Home > Help Needed / General Tech Chat > best front mount rad?
turbo22
Member #: 3684
wisborough green west sussex
hi
I am wanting to do a front mount rad on my project and i have researched everything posted on here but would just like to get a few ideas on which rad is most popular for reliabilty!!! i idealy want to go alloy similar to that in project tangerine but any other ideas would be great!!!
cheers pete
Anton
Member #: 764
Staffordshire
I have the Mk1 metro (the one with the inlet and outlet on the same side) and it works great, good great tho imo, cant seem to get enough heat into the engine. i think its copper rad.
I believe the fiat chinqwcento (sp?) is similar but made of ali...
turbo22
Member #: 3684
thanks for the reply ill try find something,also is it easier to have the inlet and outlet on the same side???
Mine Muhahahahah!
philc
Member #: 1346
bromsgrove
have you made an additional bracket on you alternator or is that a standard one???
Its a Denso. And they are standard brackets. The alternator has been modded slightly.
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
Dunno wether im gonna get away with a mk1 metro rad and a standard alternator, what you reckon??
Turbo 22, its all down to how big you want it and yeah the connections on the water pump end are good, just means less plumbing and less of a headache to find the right hoses.
philc
Member #: 1346
bromsgrove
have you a closer pic of this for me to look at. thanks
Under a clubby you should be ok. Under a round nose, no chance.
Probably the best i have to hand
This is my Fiat Cinquecento rad, its made out of copper so quite heavy but VERY efficient. *wink*
Edited by matty on 17th Oct, 2008.
philc
Member #: 1346
bromsgrove
it looks like you have take the nogging off an old alternator and welded it on??
[quote=MikeRace,17th Oct, 2008]Under a clubby you should be ok. Under a round nose, no chance.
No, my alternator must have been a different types to the usual ones ive seen as it has the extra bit on the left handside.
turbo22
Member #: 3684
thanks for all the replys guys! mikerace do you know the make of your rad or where it or somthing similar can be found??
cheers
Scruffy
Member #: 328
Seaford Rise, South Australia
Mike what tyres do you have fitted in these pics? I presume rims are 7x10s? Thanks
On 5th Sep, 2011 Vegard said:
Alex1340
Member #: 111
Loughborough
This is my front rad, its a fiat one. Fits in alright tight on the starter. i didn't want to cut to much out the front pannel.
