Home > Help Needed / General Tech Chat > startup help
stockodaz
Member #: 4055
teeside
hi i wonder if anyone could help me today was startup day on my turbo mini before i took old engine out i disconnected battery by removing earth terminal when i connected it back up to try and start car the car is turning over on its own as soon as i try to connect earth the ignition is definatley off keys arnt even in the car does anyone have any idea what it could be im totally at a loss as to what it could be thanks
Which starter motor are you using ???
Pre-engaged or Inertia ???
Do you have a wing solenoid or is your start wire connected direct to a solenoid on top of the starter ???
Seems like your heavy leads and solenoid wiring are incompatible with your setup.
stockodaz
Member #: 4055
teeside
hi im using starter that was on turbo engine it looks exactly the same as was on my 998 it has 3 brown wires that go to 1 threaded there is no other connections to it
