| Home > Help Needed / General Tech Chat > Pugeot 106 .....ot | |||||||
19th Oct, 2008 at 10:47:29am
I recently stuck a new engine in a friends 106, well, not new, a second hand lump for 100 quid, we cannot for the life of us get it to run, all or most of the sensors are connected, we get fuel at the supply pipe and a spark on the coil pack plug extensions, its like it wants to fire as soon as the key is turned as the speed of the starter increases, then just drops to a steady crank. Does every sensor have to be connected to make a circuit as we have no radiator fitted yet? 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
19th Oct, 2008 at 12:35:49pm
you might find it has a cold start system on it and with no rad sensors connected its not putting the cold start system on. stick the rest of it in (or even just connect up the sensors)
19th Oct, 2008 at 02:23:15pm
fit everything, double check everything is plugged in and you have spark fuel etc then tow then tow start the fucker. ive only ever had 2 engines in the past that wouldnt start for love nor money dragged them round the block and hey prestow. make sure who evers in the car behind is trustworthy lol no longer a series, but still 1.3 turbo.
19th Oct, 2008 at 04:46:12pm
Cheers guys, will let you know how we get on 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
