| Home > Show Us Yours! > 1380 stage 4 head supercharger project **warning SLOW build** | |||||||
![]() 902 Posts Member #: 111 Post Whore Loughborough |
19th Oct, 2008 at 12:24:52pm
Hi Guys,
![]() 300 Posts Member #: 1746 Senior Member Kent |
19th Oct, 2008 at 09:54:37pm
Nice cant wait to see this project, will you me making your own manifolds or buying them?
20th Oct, 2008 at 07:51:39am
bought some that i plan to moded to give a form of charge cooling... more will be reiveled.
20th Oct, 2008 at 06:49:05pm
Right, this is my idea, I have bought a premade set of manifolds which i then plan to get modd think it will be more than i can do so may need to sub contract the work out
22nd Oct, 2008 at 08:59:28pm
520 Posts Member #: 2093 Post Whore Grenoble, France |
24th Oct, 2008 at 01:39:47am
I'm not sure to understand what you are trying to do. You don't want I/C, right ?
Edited by alpa on 24th Oct, 2008. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
24th Oct, 2008 at 10:52:38am
the cooling will be a seperate systerm having it's own radiator like a charge cooler. So will reductce the. Charge temp
24th Oct, 2008 at 11:10:32am
Good idea Alex.
24th Oct, 2008 at 11:31:47am
I've no idea how much heat transfer there will be between the inlet gasses and the manifold Walls but there must be a fair bit or your exhaust would not get hot to touch. I think I'll use aomthing like a bike rad and electric pump to cool it. Cheers |
29th Oct, 2008 at 07:43:21pm
got my manifolds though to day. Need to get two 90deg 2inch bends from a exhaust place now then I can start cutting and welding access to a band saw would be good, have to work on that.. Changed plan alittle the top half of the "sleaving" boxed rather than tube all the way round. Will be easyer to make. Cheers |
29th Oct, 2008 at 08:03:34pm
An idea would be to box out the whole of the plate the attaches to the blower.
2nd Nov, 2008 at 07:14:13pm
2nd Nov, 2008 at 07:15:42pm
started playing, was hoping to get things done in metal, but the Mrs had a parking fopar in her Audi so i had to pull the bumper out and nock out the dent which took alot of time.
2nd Nov, 2008 at 07:20:09pm
where are the injectors/ carburation going to be situated? On 26th Oct, 2004 TurboDave16v said:
2nd Nov, 2008 at 09:35:08pm
carb up front as per normal on this convertion. |
3rd Nov, 2008 at 02:12:55am
Will be good to so the results of how this works compaird to the standard charger conversion. Make sure you keep updating the project, im going to be cooling my inlet, but its wont be anywhere near as good as this, as i plan on using a downdraft inlet and just using the standard built in inlet cooler pipes.
3rd Nov, 2008 at 12:40:08pm
i really hate to put a downer on this, but i really think the results from this will be minimal if anything.
3rd Nov, 2008 at 06:51:18pm
you may well be right but I can't think of any other way of getting any cooling. I hadwonderd about wraping the manifold with cooper tube wound round the manifold as a Easyer way to test to see if any power is gained but I think that would be even less effishant. |
4th Nov, 2008 at 12:00:49am
so does the blower have some kind of mount or brace or does it all hang on the manifold?
4th Nov, 2008 at 11:02:00am
normally yes the full weight is on the manifold but vmax do a extra brace which I think I will either get or make my own |
8th Nov, 2008 at 04:44:12pm
Right got abit done today, spent some time smoothing the manifolds getting rid of the bummpy welds to smooth out flow.
444 Posts Member #: 2885 Senior Member |
10th Nov, 2008 at 07:59:46pm
use a long bolt going through a sleeve in the water jacket?
10th Nov, 2008 at 08:50:06pm
the problem is the manifold inlet tube blocks the hole so you have to angle the bolt into the hole then drop it though hole and tighten it up. Do we think coiling copper tube round and brazing to the steel manifold will transfer much heat? Could then just flow water though the tube.
10th Nov, 2008 at 11:40:20pm
also another thing to maybe consider is fuel condensing on the inlet wall, im not sure whether this will be a big issue at all, butbest thinking about it now rather than later "Turbo's make torque, and torque makes fun"
10th Nov, 2008 at 11:52:31pm
I too am concerned with the theory behind this.
