Home > Help Needed / General Tech Chat > Kad internal gear linkage
barkiboi
Member #: 591
Rugeley, Midlands, England
Has anyone fitted one of these, just fitted it but cant get it into gear am hoping its not set up correctly as i would cry if the engine and gear box have to come out again, any ideas???
Chris
Dicanio
Member #: 91
I had a similar problem with mine, the trick is to put the gearbox in first with a screwdriver before attaching the KAD stuff (first is twisted anti clockwise and pulled out).
Then connect the KAD unit and adjust so that the gearstick is in the first gear position. This should give you a starter for the more refined adjustment.
