Home > Help Needed / General Tech Chat > ANY WIRING GURUS HAVE A LOOK
t3gav
Member #: 229
Gavin@minispares.com
kent
------------- oil pressure switch
_____|_____ |___connect into loom___|
! 2 ! |warning lamp
! ! --------! -- 1 - 4 5-!-----------pos 3 on
| ! | | ! ignition switch
| ! | |3 !
| optional |
| dash light |
+ (pump on) |________pos 2 on ignition 2switch
pump
earth
ok nos 1-5 are the relay terminals with 3 being connected to 4, this is the diagram i got from a site but i had to change the wires to 2 and 5 around otherwise the car starts on ignition pos 2, the car now runs fine but if i earth the oil pressure switch wire the pup will not die, i dont want to die in a crash can anyone help?
I've not got a clue what all the jargon above your words "ok nos 1-5 are the relay terminals with 3 being connected to......." is acutally meaning...
minimark
Member #: 19
newcastle
WTF
t3gav
Member #: 229
kent
sorry it did look right when i did it but when i posted it it came out crap, check out www.sgodfrey.pwp.blueyonder.co.uk/mini/turbo/MiniWire1.jpg for the diagram, the oil pressure wire and pos 3 ignition wire are switched round though
speedster turbo
Member #: 244
best bet for pump wiring is to have a look on page 2 of the "how to" section of this site.
Speedster turbo under construction
kayball
Member #: 67
Hitchin Herts.
See the wiring diagram for the Mini ERAon our site.
Full description and circuit under 'Technical' on Left of page, then Wiring Diagram.
http://www.eraturbo.com
Regards
kayball
t3gav
Member #: 229
kent
whats wrong with my one then? looked at gibbos how many terminals does the relay have, 4? also it just says connect when ignition is on is this pos 2 or 3. my car is getting an mot tomorow so would like to get it sorted, cheers for looking
