| Home > Help Needed / General Tech Chat > carb plenum help | |||||||
60 Posts Member #: 4055 Advanced Member teeside |
20th Oct, 2008 at 08:01:40pm
hi tried to start turbo engine for first time today and had petrol filling my plenum up does anyone have any ideas or tips to try to find problem am sure pipes are in correct places as was working off a picture |
20th Oct, 2008 at 09:41:16pm
Make sure the pipes are on correct if the fuel pipe is connected to the wrong point it will fill the plenum as you described! i learnt the hard way on my first build cost me a fiver! There is a picture on here somewhere try the search!. ron
20th Oct, 2008 at 09:59:32pm
hi i searched on here and used the carb connection photo on most veiwed images pretty sure there on ok |
20th Oct, 2008 at 10:46:39pm
sounds like the float needle may be sticking, take the dash pot off and switch on the pump see if you can see fuel pouring from the jet. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
21st Oct, 2008 at 08:00:57am
^^^ That is what I would have said, or your fuel pressure is set too high. http://www.twin-turbo.co.uk
21st Oct, 2008 at 06:17:48pm
thanks for help much appreciated think i may have been folowing wrong arrows on regulator i have 1 on top going 1 way and 2 underneath going another way i followed top arrow for fuel in not sure if this is correct |
21st Oct, 2008 at 06:51:08pm
Have a look in the FAQ to check your pluming. tehre is a post near the top that I've just fixed the pics on.... On 17th Nov, 2014 Tom Fenton said:
