| Home > Help Needed / General Tech Chat > k1100 16v 8v 1293cc Everyday | |||||||
69 Posts Member #: 1670 Advanced Member |
21st Oct, 2008 at 03:42:51pm
What are they like as a daily, who uses one most of the time, is there any problems with bore number 1 getting hot with a dry deck and whats the mpg like??
21st Oct, 2008 at 04:05:54pm
cant imagine them being any worse than a normal mini.
21st Oct, 2008 at 04:36:46pm
thank you iain |
21st Oct, 2008 at 04:47:53pm
If you build it to last there is no reason why it won't? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
21st Oct, 2008 at 05:11:46pm
I am hoping mine will be a daily driver of 100 miles a day. all on straight roads at 70ish mph |
![]() 368 Posts Member #: 362 Senior Member durham area |
21st Oct, 2008 at 05:48:04pm
bin driving mine every day for the last 5000 miles no problem all at speed some a little enthusiastic returning 32mpg and hasnt being set up on rollers yet coming apart for body work over winter will probably strip enging just to check it over, tis a 1380 16v ith lt cams. love that straight cut scream!!!
123 Posts Member #: 1234 Advanced Member Chester |
22nd Oct, 2008 at 12:07:17pm
I'd say these engines make a great all round road motor. Mine is 1380 16v with RS cams. If it's set up properly with decent cold start maps it will be really user friendly giving 5 port race engine power without the fuss. If you stick to the BMW cams you get a flat torque curve from 3k-7k and max power at 7k.
22nd Oct, 2008 at 12:42:21pm
On 22nd Oct, 2008 nbooth660 said: Bingo! And how many modern cars designed with sealed cam covers have you seen where the belt has snapped and taken the head and some times more with it! Its a loaded gun held against your wallet waiting to go off. Its just a matter of time and who!
My only reservation as an everyday road engine would be the unkown long term relaibility. You've got to get all the oil drains and breathers right and try to keep the oil in the thing on the side of the engine that wasn't designed that way originally. I guess you've also got the risk of debris getting under the cam belt with it all being open. Just my 10p. Nick. Own the day
22nd Oct, 2008 at 01:08:40pm
althoug it seems most people are machining the piston cutouts deep enough for the valves to miss. On 28th Aug, 2011 Kean said:
22nd Oct, 2008 at 01:20:06pm
At least without a cover it is easy to see how worn the belt is! Lol
Im driving mine to Newquay next year on the Riv run. lol
