Home > Wanted > Turbo downpipe
matnrach
Member #: 1074
Northamptonshire
I'm after a downpipe for a T2 turbo i.e renault 5 std size (2inch)
Thanks
http://www.miragemotorsport.com/
matnrach
Member #: 1074
Northamptonshire
Looks like they do a facricated elbow but I'm using the standard cast elbow. I just need a S/H downpipe for the conical flange as this is tricky to make.
The flared flange (you say conical, but I assume we mean the same ???) is the tricky bit.
I've tried everywhere on the net to get a 2" stainless flared end on a 75 degree bend (that's what I measured it as) but with no luck so far.
Mild steel is relatively easy but I want stainless
matnrach
Member #: 1074
Northamptonshire
Does anybody know if a downpipe from anything else fits, maybe a 200SX?
Could you get someone like Long Life exhausts to make you one? I can't see it being more than a 5 minute job for them.
matnrach
Member #: 1074
Northamptonshire
Possibly. I guess it is very easy if you have the correct tooling
