| Home > Help Needed / General Tech Chat > Seperate oil tank for turbo feed. | |||||||
22nd Oct, 2008 at 10:43:06pm
right, i have a quesition.
22nd Oct, 2008 at 10:50:43pm
Something to do with yo pitbike? |
22nd Oct, 2008 at 10:53:16pm
nooooooooo never
Edited by James_H on 22nd Oct, 2008. |
22nd Oct, 2008 at 10:55:22pm
Didnt the minispeed superchargers have something like this?
22nd Oct, 2008 at 11:02:24pm
would it be able to cope with the thinkness of the oil compared to the washer fluid?
22nd Oct, 2008 at 11:12:52pm
How long a period is this thing going to be used for?
23rd Oct, 2008 at 06:43:47pm
Would gravity feed work?
23rd Oct, 2008 at 08:21:31pm
make an eltric pump for it? Rc car motor 12v and use some type of air suction to get it to move :) Drives
444 Posts Member #: 2885 Senior Member |
24th Oct, 2008 at 06:31:51pm
surely turbos are designed to use engine oil feed at like 60-70psi so will a low pressure seperate feed work=no.
24th Oct, 2008 at 09:01:36pm
hario - the problem is the engine is only splash lubricated so there is no oil pressure there to use.
194 Posts Member #: 2873 Advanced Member Milton Keynes |
25th Oct, 2008 at 04:13:29am
wat about a fuel pump? just strip it and remove the filters so it can't get clogged up so its a stright thru pump. |
25th Oct, 2008 at 08:32:33am
First you need to know the oil pressure and flow requiremnts of the turbo.
On 24th Oct, 2008 James_H said:
unfortunatly leccy oil pumps are a tastey 180ish mohunies. so more option needed really. i dont want to be spending that much on a pump. if you want to go electric they can be had for 80 rather than 180 http://cgi.ebay.co.uk/Oil-Pump-Diff-Gearbo...id=p3286.c0.m14 Edited by Rod S on 25th Oct, 2008. Schrödinger's cat - so which one am I ??? |
25th Oct, 2008 at 10:41:56am
rod you are a legend!
so i am aprehensive about tapping into the engine oil and then putting the pump from there blah blah blah.
