| Home > Wanted > Couple of Bits Wanted | |||||||
26th Oct, 2008 at 09:16:38am
BDD Needle Wanted, can swap for either DER or BDK Needle.
![]() 1014 Posts Member #: 238 Post Whore essex |
26th Oct, 2008 at 11:27:21am
probably got a crankcase breather (non servo type), and the gearbox bracket, will check and let you know. ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
27th Oct, 2008 at 12:43:37pm
Any Update on this mate?
On 26th Oct, 2008 adam1330 said:
probably got a crankcase breather (non servo type), and the gearbox bracket, will check and let you know. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
27th Oct, 2008 at 04:10:01pm
yep got both bits.
