Home > Technical Chat > 1360 Rally Turbo
Mayfairmad
Member #: 1771
Hey,
I have a 1360 rally prep engine, 276 kent cam, dished omega pistons, 1275 crank, cooper 'S' gearbox, stage 2 head, hiff 44 carb. it has the Rally CR to
What wouldi need to do in order to be able to fit a turbo to it. i know about the turbo carb and turbo crank but dontknow what else is needed to be done.
Dan
Ben H
Member #: 184
Melton Mowbray, Pie Country
I hate to be the first to say this but SEARCH. Get an understanding of what you need and then ask specific questions.
To gauge how much you have searched tell us what you KNOW about the turbo crank?
http://www.twin-turbo.co.uk
rallying? what class would you be aiming to be in? up with the 1.8/2L boys?
sorry, 'rally prep' engine, should learn to read first
OK, I'll be second....
What do you mean by the "rally CR too"
If you're thinking turbo, you should be thinking what CR you need for the boost your thinking of ????
EDIT - just realised my english here is appalling... what I meant was if it's been built with a suitable CR for that spec cam, it could well have had the CR raised.
If you're thinking turbo now, as a generalisation, CRs would normally need to be lowered but, more to the point, you need to think ahead - what level of boost do you intend to use - then choose the CR accordingly.
Edited by Rod S on 28th Oct, 2008.
