Page: |
Home > Show Us Yours! > Pistons | |||||||
7262 Posts Member #: 1268 The Boom Boom speaker Police! Essex |
28th Oct, 2008 at 10:56:29am
On 28th Oct, 2008 BENROSS said:
gary, pics of the bores please! I'll get some tonight if not tomorrow. From what I remember though, they all look good other than the mark on pot 1 that was visible before the strip down. In the 13's at last!.. Just |
7763 Posts Member #: 74 I pick holes in everything.. Chief ancient post excavator |
28th Oct, 2008 at 11:14:55am
Why not use this block, and get some 040 pistons instead of getting another block as in the other thread? On 13th Jul, 2012 Ben H said:
28th Oct, 2008 at 11:38:00am
On 28th Oct, 2008 Vegard said:
Why not use this block, and get some 040 pistons instead of getting another block as in the other thread? I was considering it, but I've already spent money on a head to suit, so don't want to increase the CR. In the 13's at last!.. Just |
8297 Posts Member #: 408 Turbo Love Palace Fool Aylesbury |
28th Oct, 2008 at 11:45:23am
I would of thought they'd be equaly bad in pairs (inners/outers). Sounds like cylinder 4 hasn't been able to dissipate heat aswell as the others, if it is substantially worse?
28th Oct, 2008 at 12:25:51pm
Ive seen in pics of your car gary that you have the heater tap blanked off on no.4 end, I have too.
28th Oct, 2008 at 12:33:23pm
Nope, I'm still using the heater plumbing. I left it there because of this the possible heat problems and cos I like it cosey in the cabin.
Edited by theoneeyedlizard on 28th Oct, 2008. In the 13's at last!.. Just |
2485 Posts Member #: 1954 Post Whore Luton Bedfordshire |
28th Oct, 2008 at 12:38:45pm
On 28th Oct, 2008 richminiturbo. said: You have no efficent way of removing the hot water from around number 4 cylinder. I run a copper pipe from the heater tap take off across the back of the rocker cover into the bottom hose of the rad so I have a constant circulation of coolant.
Ive seen in pics of your car gary that you have the heater tap blanked off on no.4 end, I have too. Was wondering if I was going to run into any problems by blanking mine off, could the problem here be related to this being blanked? Own the day
4300 Posts Member #: 1321 Post Whore Wiltshire |
28th Oct, 2008 at 01:46:21pm
On 27th Oct, 2008 Paul R said:
talking about buggerd pistons what do you think about this... They look like they have pretty much served a long stint in an engine, even excluding the huge ding in the bottom (dropped mabie) I wouldn't use them, I'd source a better condition set. I'm guessing they are standard bore, hense wanting to use them in that condition. Edited by minimole23 on 28th Oct, 2008. On 7th Oct, 2010 5haneJ said:
28th Oct, 2008 at 02:07:00pm
On 28th Oct, 2008 Mr Joshua said:
You have no efficent way of removing the hot water from around number 4 cylinder. I run a copper pipe from the heater tap take off across the back of the rocker cover into the bottom hose of the rad so I have a constant circulation of coolant. With regards to this, how have you plumbed it back in to your bottom hose? I'm using a front mounted radiator and have not yet got any of the hoses, I need to make an adapter for the bottom hose, to which the feed from the header tank will be connected to, will I need to do the same for the heater tap take off? I've been pondering about this for a while, wasn't sure if I really needed to keep the flow going past number 4 but I'd rather be safe than sorry!! Edited by richminiturbo. on 28th Oct, 2008. |
28th Oct, 2008 at 02:30:23pm
Why not use this block, and get some 040 pistons instead of getting another block as in the other thread? I was considering it, but I've already spent money on a head to suit, so don't want to increase the CR. Have you calculated the difference? It's fuck all. On 13th Jul, 2012 Ben H said:
28th Oct, 2008 at 02:42:39pm
Right I've made a note of where the damage is on each piston and made a little diagram. On 28th Aug, 2011 Kean said:
28th Oct, 2008 at 03:30:24pm
V - I've not done the calcs yet. Thing is, the pistons are running .8 mm down the bore. I was intending on getting them level with the deck. I assumed that this, plus the increased bore would take it up quite a way.
6549 Posts Member #: 1149 #1 Basshunter Fan Force Racing ICT Dept Manager Miglia Turbo Am frum Yokshyer tha noes! |
28th Oct, 2008 at 03:54:36pm
The piston sitting further down the bore would DEcrease the CR. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
1849 Posts Member #: 672 The oversills police Oslo, Norway |
28th Oct, 2008 at 04:26:27pm
if you go 040 and make the pistons sit flush you will end up with 9.19:1 CR. if you keep them 0.8 mm below the deck you will have a CR of 8.5:1 |
28th Oct, 2008 at 04:47:47pm
the difference in bore will make about 0.2-1 difference to the comp ratio,
28th Oct, 2008 at 04:53:51pm
Joe - that's weird?!? It must have worked at some point as Matty has made comment on it. I'll sort it in the morning. Nah ive never seen this pic either, I was just commenting on the first pic and the descriptions you've given about which one was worse. .....Unless the picture is supposed to be a red cross? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
29th Oct, 2008 at 09:05:01am
Fixed the image.
29th Oct, 2008 at 09:29:26am
interesting, thats pretty much the opposite of what i was expecting. On 28th Aug, 2011 Kean said:
29th Oct, 2008 at 10:50:28am
On 28th Oct, 2008 richminiturbo. said: The bottom hose for the rad has 2 return lines in it. I believe I took it from an SPI I was breaking could even have meen an MPI. But it allowed me to retain full control of my heater matrix and allow full unrestricted flow from around number 4 piston I had to fabricate the copper pipe and braze an extra piece on so I can run the system as I wanted hope the pic is clear.
You have no efficent way of removing the hot water from around number 4 cylinder. I run a copper pipe from the heater tap take off across the back of the rocker cover into the bottom hose of the rad so I have a constant circulation of coolant. With regards to this, how have you plumbed it back in to your bottom hose? I'm using a front mounted radiator and have not yet got any of the hoses, I need to make an adapter for the bottom hose, to which the feed from the header tank will be connected to, will I need to do the same for the heater tap take off? I've been pondering about this for a while, wasn't sure if I really needed to keep the flow going past number 4 but I'd rather be safe than sorry!! You can see the two return lines coming out just behind the rad to the left of the cap. The copper pipe feeds into the lower pipe and the heater return feeds into the upper pipe wher I have positioned a later type heater tap. Edited by Mr Joshua on 29th Oct, 2008. Own the day
29th Oct, 2008 at 11:00:03am
On 28th Oct, 2008 richminiturbo. said: Back in 2003 I melted No.4 piston! Sinc I have run like this No problems with melting pistons and I am running more boost for more of the time.
With regards to this, how have you plumbed it back in to your bottom hose? I've been pondering about this for a while, wasn't sure if I really needed to keep the flow going past number 4 but I'd rather be safe than sorry!! Edited by Mr Joshua on 29th Oct, 2008. Own the day
Page: |
