Home > Technical Chat > Piston and gear ratios
T-shirt
Member #: 2461
Portsmouth
Hello all,
Couple of questions for you all.
Can someone advise of a +0.060' forced induction piston with an 18cc dish (or equivilent) for an engine of 200+ hp. Vizard recommends not to use Omega cast in engines exceeding 170hp (shot peened radius helps), however I think the 18cc dish only exists for +0.020.
Also, is there information/ software tool available that can tell me max speed per gear based on rev limit, wheel size gear, diff ratios etc.
I have tried searching but with no success.
Thanks in advance!
Chris.
Accralite pistons would suit - http://www.avonbar.com/product/?pid=5759
T-shirt
Member #: 2461
Portsmouth
Thanks for the info.
Sorry forgot to mention, will be utilising standard stroke.
I dont think they have +0.060'. They have 1310, and 1380 but not 1330. Thing is, why do they refer to the pistons in cc rather than bore size???
mr t , have a look for 'gearcalc'on google .
regards
pm me you email address,
i have a mini based gearbox calculator, i'll try to email it to you.
