| Home > General Chat > Hard drive data recovery | |||||||
29th Oct, 2008 at 02:30:39pm
im having a few probs can any one help?
Yes i moved to the darkside |
249 Posts Member #: 513 Senior Member Sheffield |
29th Oct, 2008 at 03:04:14pm
You were running raid 1 and not 0? |
29th Oct, 2008 at 03:05:16pm
I also use RAID and the only obvious question, if it won't rebuild on a new drive from the BIOS, is have you got a compatible drive for your replacement, and is it jumpered right (if it's IDE).
29th Oct, 2008 at 03:07:36pm
On 29th Oct, 2008 andygardner said:
You were running raid 1 and not 0? Good point, I'd assumed from the intial post it was mirrored and not striped.... Thinking on, you also mention 4 HDDs..... were they all in the array ??? Schrödinger's cat - so which one am I ??? |
29th Oct, 2008 at 03:21:27pm
it was 2 80 gig sata drives that was mirrored i think its raid 1?
Edited by Brett on 29th Oct, 2008. Yes i moved to the darkside |
29th Oct, 2008 at 03:33:07pm
Good luck !!!!
29th Oct, 2008 at 03:51:10pm
ahh well i dunno, lol the sata raid was my first go at sata, all my other drives was ide, like you say i dislike it because untill now i have had noway to get info off other than copying via windows (i often take one of my ide drives up to my bro's lol) but i cannot fault it for its speed, about 3Gb/s rated usualty 2.5Gb tops as opposed to an ide drives speed of 150mb/s Yes i moved to the darkside |
29th Oct, 2008 at 03:54:18pm
the software is called "find and mount", and a limited free version is at here limited at 0.5Mb/s lmao Yes i moved to the darkside |
and ive hit a snag, using my lappy as the work horse i have discovered the original boot drive (the working one) only has full unallocated space in it witch cannot be opened / access untill its formatted but this would delete all the info on it
