Home > Help Needed / General Tech Chat > gearbox fault...?
adam1330
Member #: 238
essex
had to get a bump start earlier, as the battery was a little flat. So with the position the car was in at the time i decided to bump it backwards..
it did start, but with a bit of a jolt!
i drove off and instantly could tell that something was wrong, there is a strange noise coming from the gearbox, but only really under load, i'm thinking something to do with the diff?
Also i managed to snap the top engine stabiliser bolt, in the engine! this is not too much of a problem as i have one of those repair brackets that bolt onto the flywheel housing.
So what do you think i could of damaged in the gearbox?
even less impressed as i was planning on taking the car off the road after friday to do a few things over the winter, and a gearbox wasn't one of them!
Edited by adam1330 on 29th Oct, 2008.
turbo hogster
Member #: 178
stowmaket suffolk
is it in all gears mate or in a specific gear
adam1330
Member #: 238
essex
think it was me being paranoid, i fixed the top engine stabiliser and now it seems alright, must have been where the engine was loose and vibrating on something?
i hope!
turbo hogster
Member #: 178
stowmaket suffolk
proberly exhaust hitting under neath if it was lose.
is it the helical box i rebuilt for you
adam1330
Member #: 238
essex
yeah still the same box you built for me, been going fine so hopefully it was just me worrying...!
I wouldn't bump start in reverse. It will put a tremendous load on the little shitty gear with no bearings.
