Home > Technical Chat > IAT Sensor
I'm after a bit of info on how these work if anyone can help, I know that they are effectively a resistor that varies in resistance as the air temperature changes but does anyone know what resistances relate to what temperatures?
I did a bit of a google search but all I could find was info on how to replace an IAT sensor and how to fit a resistor to give you and extra +15 BHP.
An example of a Bosch one I was thinking of using...
The data for the Leyland/Rover ones is imposible to find, I decided to use Ford sensors instead as I have a copy of the relevant manual that has enough data points to put into the EMS...
http://www.bosch-motorsport.com/pdf/sensor...e/NTC_M12-L.pdf
Cheers that's exactly what I was after.
No problem... there's temperature/resistance curves for the standard GM (USA) ones on the meagasquirt site somewhere as well.
The shape of the curves (ie, negative temperature co-efficient) are all similar but actual values on the curve vary from each manufacturer from what I found - hence the EMS requiring me to enter a number of points to set the curve.
(Edited for spelling...)
Edited by Rod S on 30th Oct, 2008.
*tongue*
Rover coolant sensor resistance readings, i had to scale this sensor for VEMS so i have a reasonable log of resistance versus temperature at 5 degree intervals, still got to measure 20,15, 10, 5, -5 and -10 degree points, but using Easytherm, it can generate curves from three points. I use a chip pan and oil to get the higher temperatures, but also to give a much steadier cool down rate so to stabelise the sensor readings as the coolant temp sensor is quite a large chunk of brass. It all took about three hours!! This was using Calibrated instruments, and is not representative of the two points I got from Lucas for these sensors!! which is 2000 ohm at 25c and 182 ohm at 100c
DegC - Ohms
-10 -
-5 -
0 - 5850
5 -
10 -
15 -
20 -
25 - 2066
30 - 1725
35 - 1433
40 - 1211
45 - 1030
50 - 885
55 - 756
60 - 643
65 - 558
70 - 481
75 - 419
80 - 367
85 - 320
90 - 279
95 - 246
100 - 218
105 - 192
110 - 172
115 - 153
120 - 140
125 - 130
