Home > General Chat > How To Run Garage Lights
Markie_D
Member #: 1660
Formally Mini_Uk
London
Need some advise please.
I need some lights in my garage. is it possible to run lights of a separate car battery ? if so, what kind of lights can i use, and what would i need to connected it all up. or would i need a Generator.
Don't know anything about Generators. the one in the link says it uses fuel. would there be alot of fumes i take it ? it has to be more or less very quite.
http://cgi.ebay.co.uk/SILENT-SUITCASE-DIGI...A2%7C240%3A1318
Anyone who has done this before, and knows about kind kind of stuff. be kind enough to give me some info please :)
Thanks alot.
Edited by Markie_D on 31st Oct, 2008.
Shit Happen's
Mr Joshua
Member #: 1954
Luton Bedfordshire
I bit the bullet and ran a 30m extension line to my garage and fitted strip lights there is no substitute.
Own the day
i had a little rig that used 4 mini headlights and it run of a big battery for about an hour or so.....then i just moved so didnt need to any more
Caravan type flourescent lighting is the closest you will get to decent 12V lighting that doesn't flatten your battery in an hour.
But it's still c**p compared to 240V
Sam
Member #: 1686
Oxford
id run a line from your main house at 240 volts.
for this i used the same stuff they use on the motor way for running the lights, works wonders.
then into a switch box like you would on your normall house.
then you wire up strip lights and sockets.
jobs a good en.
OMG Robert that's a big one
Mini_Andy
Member #: 432
run a seperate fuse box from the house mate, its the only way!
Markie_D
Member #: 1660
Formally Mini_Uk
London
Running something from the house is a no no, as the garage to a good 200 yards from the house.. wont work :( would that silent DIGITAL GENERATOR be no good then ? to much fumes ? it's just so when i'm working on my car. as the engines coming out. wished the garage was nearer to the house.
Shit Happen's
Markie_D
Member #: 1660
Formally Mini_Uk
London
What if i had a good few of these planted around in the garage, do you think it be good enough. ?
http://cgi.ebay.co.uk/STICK-ON-LED-LIGHTS-...A2%7C240%3A1318
Come across this also lol http://cgi.ebay.co.uk/HEADLIGHT-12-LED-PIK...bayphotohosting
As it's so dark in there, i need every bit of light. looking like a Knob in the mean time lol
Shit Happen's
Mini_Andy
Member #: 432
whats in between the garage and the house?
Markie_D
Member #: 1660
Formally Mini_Uk
London
Abig wall, and people walking past. which is not going to be an option :(
Shit Happen's
Mini_Andy
Member #: 432
damn, i would go for a genorator then, just keep it out side when using it, or run a pipe outside for the fumes :)
Markie_D
Member #: 1660
Formally Mini_Uk
London
Lol.. so with the genorator, doe's it have to be on everytime your using it i take it. that one in the link. how many 100 watt bulbs would you say it could run, just want to get an idea of what it can handle so it's not overloaded...
Shit Happen's
The eBay listing says 850Watts (continuous) so 8 @ 100W bulbs or 14 @ 60W...... etc.
Markie_D
Member #: 1660
Formally Mini_Uk
London
Gotch ya..
Cheers *wink*
Shit Happen's
evolotion
Member #: 83
Glasgow, Scotland
big leasure battery, good inverter and fluorescent strip lights. if your going to run a "remote" lighting setup you want the most efficeint lights you can :) as said above the 12v caravan lights are a bit pants so inverter and proper lights is a decent compromise. Just dont use incandescent lights, waste of energy :)
Denis O'Brien.
evolotion
Member #: 83
Glasgow, Scotland
http://www.unlimited-power.co.uk/low-volta...12v-dc-CFL.html
some lights with 1000+lumens output, thats decent.
find these in teh uk http://www.powerstream.com/ballast-1.htm and you can run normal big flurescent lights off 12v *happy*
Denis O'Brien.
barkiboi
Member #: 591
Rugeley, Midlands, England
Use energy efficent light bulbs will get more light of less power consumpition
Markie_D
Member #: 1660
Formally Mini_Uk
London
Thanks for that,
Thiink i might try that out.. what kind of wire should i use ?
Cheers.
Shit Happen's
If you want a proper generator (the eBay listing you started with isn't a proper generator), I was in my local B&Q this morning and they were selling 2.8kW generators for the same price (£149).
I don't know if all branches would have them but you usually see them in the bigger branches at this time of year.
hario
Member #: 2885
flourescent tubes run about 70watts for a normal one, i bought a tiny inverter from ebay for 9.99, its lik e asigarette lighter with a dongle on the back with a mains plug in it, good for one light an itll last for ages on a decent car battery.. *tongue*
ebay eBay EBAY ! lol
Markie_D
Member #: 1660
Formally Mini_Uk
London
I got these in the end
http://www.screwfix.com/search.do;jsession...chbutton=submit
I mounted it on the celin. nice bit of light comes down. might get another one up there.
I'm going to get an inverter, and a good battery as a back up, incase i'm in there all day at a weekend, and the charge on the lights start to run out,(as it's a rechargerable light of course) i'll just plug her in. can you get an inverter where you can use to plugs ?
Cheera
Shit Happen's
T-shirt
Member #: 2461
Portsmouth
Yeah if its just lighting your after than your best suited with rechargable lanterns.
You can get various types, incl an adapter where you can remove the rechargable battery, take it home, charge it then reconnect it as you would do a battery operated drill.
I know speedy hire do some decent units which give lots of light and last for approx 8-10 hrs. They can also sell the units to you if you would rather not hire.
Regards,
Chris.
