| Home > Technical Chat > Older A series cams | |||||||
152 Posts Member #: 1074 Advanced Member Northamptonshire |
1st Nov, 2008 at 08:12:39am
1st Nov, 2008 at 08:26:48am
I'm 99% certain the bearing sizes are the same, so any (1275) cam fits any block, but pump drive connections are different on the earlier engines, a star and spline arrangement rather than peg/slot.
1st Nov, 2008 at 08:30:39am
Thanks,
1st Nov, 2008 at 09:10:52am
I've never seen it myself but, according to Vizard, some early cams had narrower lobes but as long as you use new followers with your new cam it shouldn't be an issue. There is nothing in Vizard to suggest the recesses around the followers were machined any differently if it was using a narrow lobe cam but, like I say, I've never seen a narrow lobe one anyway. A trial fit would soon confirm.
Edited by Rod S on 1st Nov, 2008. Schrödinger's cat - so which one am I ??? |
1st Nov, 2008 at 09:26:22am
Wow thanks for that info.
1st Nov, 2008 at 11:37:37am
what Rod said :)
