| Home > Help Needed / General Tech Chat > Engine Crane | |||||||
69 Posts Member #: 2461 Advanced Member Portsmouth |
1st Nov, 2008 at 05:08:38pm
Hello all,
1st Nov, 2008 at 05:20:13pm
i made a bracket from a flat bit of sheet metal about 2mm thick and an inch wide.
1st Nov, 2008 at 05:33:06pm
i have a friend who always pulls his engine out by the rocker shaft! not something i would recomend!
1st Nov, 2008 at 06:19:53pm
On 1st Nov, 2008 T-shirt said:
....but it has only come with one chain and hook. Has anyone else experienced this problem???.... Normal for a basic engine crane..... how many real cranes do you see with more than one cable and hook :) How you rig it beneath that single hook is the question. On 1st Nov, 2008 T-shirt said:
Can anyone advise how they winch the engine out and what adaptions they make if any? Also what points do you use to winch from?? I've been meaning for ages to make up the bit of angle that goes across the rockers, I even measured it up the other day... (it has to be slightly offset to one side)
But normally I use rope.
1st Nov, 2008 at 07:08:27pm
Awesome thanks Rods exactly what I need. Will use rope tommorrow, but will consider metal rod at a later date.
1st Nov, 2008 at 07:26:33pm
Does no one still have any of the lifting eyes that used to come as standard with the old A series (the ones that are attached to the same studs as the rocker cover bolts)They are just a bit if strip bent and drilled,almost exactly like Rod has shown above.I use these and a thick rod (same as Rod !!) and two Mole grips to secure the rod between the eyes. |
![]() 159 Posts Member #: 1997 Advanced Member Lichfield |
1st Nov, 2008 at 07:36:22pm
I just use a single piece of angle bolted to the centre front head stud and it seems to balance perfectly |
1st Nov, 2008 at 07:42:01pm
Yes, mine were actually the old lifting eyes in the photo, but I was just using them to get the offset measurement so I can make up a suitable piece of angle iron to use in the future.
1st Nov, 2008 at 07:45:59pm
On 1st Nov, 2008 Monkeh said:
I just use a single piece of angle bolted to the centre front head stud and it seems to balance perfectly The balance depends on what is actually there when you are lifting, the weight of the flywheel creates quite an ofset if the whole power unit is assembled, the radiator (if attached as I normally have on a car lift) reduces this.... I did more measurements than in this photo :) There is also front to back balance to consider when trying to get the diff out from behind the subframe :) Schrödinger's cat - so which one am I ??? |
1st Nov, 2008 at 07:58:57pm
What about the type of knot. Im not too hot on knots but the knot needs to tighten as weight is applied? Have you got a name for the knot - can do a google search on how its actually done!! |
1st Nov, 2008 at 08:10:20pm
Right, I should also say, in the photo, I use 10mm nylon rope, not 6mm and not washing line !!!
1st Nov, 2008 at 08:23:42pm
Haha! Good stuff. Shall get some of this nylon rope. Thanks for your help! |
1st Nov, 2008 at 08:47:57pm
OK,
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
1st Nov, 2008 at 10:20:43pm
i use old seatbelt - very very strong stuff and relatively easy to wrap round the engine. i go arond and cross diagonally in the middle. i also tie it with a reef knot, easy enough to undo if a little fiddly On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
2nd Nov, 2008 at 10:49:34am
What about tow rope??? Like this
2nd Nov, 2008 at 10:57:10am
I uses some random chains I brought from B&Q years ago must have used them for 50+ engine lifts by now. Isambard Kingdom Brunel said:
2nd Nov, 2008 at 11:07:40am
Tow rope would be good (providing it's long enough, which it should be, but check it first).
