Home > Wanted > NOW OBTAINED - Dizzy clamp fork and bolt for A plus
TAM1671 and TAM1706
They are an outrageous £3.82 and 52p at MiniSpares for a bent bit of metal and a bolt - I would have paid it as I'm placing and order anyway but, OUT OF STOCK !!!
I can't find mine and I want to do a quick run of the engine (out of the car) on a dizzy and carb before I get stuck into the EMS *tongue*
Beer tokens await if anyone has a fork/bolt they don't want.....
Edited by Rod S on 8th Nov, 2008.
adam1330
Member #: 238
essex
should have these bits, will check for you.
tadge44
Member #: 2500
Buckinghamshire
If the above does not work out I think I can find those parts -let me know.
Cheers both...
Adam, if you have one , PM me.
Otherwise I'll get back to you Tadge.
(I might even find my own one if I try hard enough...)
Thanks to Adam I now have one, thanks too to Tadge for offering to be the back-up.
In the next couple of days I may now get to do a test run of the engine with this funny thing called a dizzy and an even stranger thing called a carburettor ???
