Home > Introduce Yourself > Newbie!
mtheodore
Member #: 4234
Hi guys just joined your forum!
I'm busy getting bits together for a supercharged engine, thought you might be able to help?
Ok guys I need some help to plan the build on my new engine.
Can anybody tell me the chamber size i will need in my cylinder head for these pistons to achieve a CR of about 8.5 (I think this is right for an eaton M45?)
Pistons below, CC is 6-7cc
Compresion height is 1.527"
http://www.minisport.com.au/prod1152.htm
Im using a MG metro block sn.12HD17 which is not lined and has not been skimmed or re-boared.
Crank and rods will all come from this unit.
Finally I am also using a 123distributor:
http://www.tdcperformance.ca/
Can anybody recommend a starter curve? (SW5 Cam)
Again in advance many thanks to all of you
hi there and welcome! 28 cc in the head will give you around that with a +20 overboar
That's good. I'm doing the same thing with my MG motor, but with an SC12 :)
Hi BTW
