| Home > Help Needed / General Tech Chat > crap!its trying to overheat | |||||||
4th Sep, 2004 at 04:54:55pm
why is my car trying to overheat itself at the first oppotunity? |
4th Sep, 2004 at 05:59:14pm
How have you plumbed in your turbo?
4th Sep, 2004 at 09:00:45pm
mine actually cools better like that, i guess its with the overdose of coolant and the increased waterflow thats created, it runs hotter with the heater, only slightly though. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
5th Sep, 2004 at 08:56:42am
ah, i have one going from the heater end of the head to the turbo, and the other running into where the heater used to go into the bottom hose, i.e. my turbo take the place of the heater
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
5th Sep, 2004 at 09:18:14am
nick, try looping the water outlet of the turbo straight into your top hose/rad at least this way the hot water will be cooled before it goes back round your block etc. I know fiesta rst's have their turbo water outlet going straight into the rad.
5th Sep, 2004 at 09:28:59am
cheers, ill try now |
5th Sep, 2004 at 05:44:30pm
ok, well by adapting an old bottom hose and some extra tight jubilee clips i have managed to make a top hose that has a take off for the turbo,
5th Sep, 2004 at 05:52:31pm
what other problem have you know got no longer a series, but still 1.3 turbo.
5th Sep, 2004 at 06:00:09pm
generall poor running see my other thread-http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2542 Edited by Nic on 5th Sep, 2004. |
18th Sep, 2004 at 01:05:23am
right, my next plan of action was to fit a larger water pump pulley, or if that didnt work an electric water pump.........
18th Sep, 2004 at 05:03:58pm
no, its still too hot for my liking, with the electric fan on it will keep it just below the hot mark when in traffic, running it calmly on open roads sees it at just over at about 3/4s
18th Sep, 2004 at 06:29:40pm
Dan found that his gauge was a mile out! his was running right into the red. on a calibrated digi gauge it read about 75ish at the beginnin of the red!
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
18th Sep, 2004 at 07:13:04pm
Don't bother with the standard "guessometer" get a proper cappilary temp gauge fitted, then see where you are.
19th Sep, 2004 at 02:46:13am
ill try it, got to fix my latest problem though!
19th Sep, 2004 at 08:23:20pm
Atleast its flip front |
19th Sep, 2004 at 10:12:30pm
indeed!it is also very useful when fixing the frequent problems that im having
