| Home > Help Needed / General Tech Chat > Engine Stand | |||||||
69 Posts Member #: 2461 Advanced Member Portsmouth |
8th Nov, 2008 at 07:25:24pm
Hello all,
8th Nov, 2008 at 07:57:49pm
Here's how I did mine,
8th Nov, 2008 at 08:04:03pm
Thats nice Rod S.
8th Nov, 2008 at 08:07:44pm
I do it like this:
8th Nov, 2008 at 08:22:14pm
On 8th Nov, 2008 T-shirt said:
Thats nice Rod S. Did you not have any problems mounting the plate with the differing levels? How difficult is it to get hold of those bolts or are they the standard? Thanks, Chris. Cant remember but are those bolt sockets all parrellel? I basically drilled 4 holes in the supplied plate to match the holes I wanted to use in the block. The spacings (in/out) were different so I just used packers (large nuts and washers) to achieve what I wanted. Bolts/studs were just spare ones from the block (or my box of bolts) but packed out accordingly. the ones I used were all parallel (perpendicular), the one I did NOT use was top left (block to oil filter pipe) because it was not parallel to the others. Schrödinger's cat - so which one am I ??? |
8th Nov, 2008 at 08:55:44pm
Good stuff.
8th Nov, 2008 at 10:51:05pm
The brass adapter I made was simply because the hole the relief valve goes into is very large..... I can't remember the exact thread but it's the same as some central heating fittings (so probably something like 3/4" BSP) and I just used a brass "plug" that size and drilled and tapped a 5/16" UNF hole in the centre of it to take the "standard" Mini bolts.
Edited by Rod S on 8th Nov, 2008. Schrödinger's cat - so which one am I ??? |
9th Nov, 2008 at 09:20:56am
Is the oil feed bolt a Banjo Bolt 5/8" UNF? Anyone know??? |
9th Nov, 2008 at 09:29:52am
Can't remember - I could measure one if you want (I have one out in a box of bits somewhere) but remeber it doesn't go into the block straight which is why, although you can see it in my photo (top left), I didn't use it. Schrödinger's cat - so which one am I ??? |
9th Nov, 2008 at 09:34:05am
Sorry getting confused am after the relief valve thread instead.
9th Nov, 2008 at 09:55:59am
1/2" BSP (my guess last night was a size out....)
9th Nov, 2008 at 10:01:37am
http://www.minispares.com/Product.aspx?ty=...LVE%20AND%20S...
9th Nov, 2008 at 10:13:48am
Haha, it's meant to, but MiniSpares are wrong....
9th Nov, 2008 at 10:19:38am
Awesome.
444 Posts Member #: 2885 Senior Member |
10th Nov, 2008 at 08:04:29pm
i use tappet chest cover bolts and fuel pump bolts, i think four should be minimum for the weight of a complete build, can still fit pushrods.
