Home > Help Needed / General Tech Chat > damn, wont idle and missing!!
ive been having a problem with my car in that it wont idle, its been a bit of a pain but as it wasnt working properly it wasnt a problem
so today after fiddling with the cooling system i took the car for a run and whilst cruising along in 4th off boost it started to misfire a bit so i backed off and when i carried on the problem was fine.
however im also having the problem that the car wont idle very annoying, it will for about 20secs and then dies,
ive checked the fuel pressure and that was at 4.5psi, which is a bit high but its how it was rolling roaded so i could run it in, and whipped out the plugs and they were exceptionally black and sooty
any suggestions what it is? im thinking the fuel pressure is too high so its flooding the carb and stalling, i backed it off to 3.5psi but it would just stall, so ive got it back at 4.5 now
your assistance would be greatly recieved
SumpNut
Member #: 28
But the car was running fine before you re routed the water from the turbo?
no, it would never idle, but i hadnt had the missing problem before but it only did that once on the journey
SumpNut
Member #: 28
If it isnt running right, that could be the cause of it over heating.
Rolling road could be the answer here.
ass, apparently it was done last week but its running really crap at the moment,
ill give him a ring tomorrow and see what he did to it
SumpNut
Member #: 28
Where did you take it?
jukka
Member #: 60
Forgotten more than most ever know
I´d set the fuel pressure to 3,5 psi and richen the mixture a bit to begin with. SU does not like high fuel pressure and will sooner or later flood with high pressure.
What needle, what plugs ? If it has been running rich it is possible that you will have plug related misfire problems.
I've had the EXACT same problem on my car now, and it was down to too much fuel pressure.
I had the same on my old turbo and that was too high a fuel pressure and also hard choke seals in the carb *smiley*
assuming you've rebuilt the carb with new seals but just thought id point it out.
ah ha sorted! the carb was rebuilt yes, but the problem was down to the float valve being faulty or something and not being able to take the vibrations of the engine,
ive changed it this morning and my problems with it running poorly are gone
