| Home > Help Needed / General Tech Chat > Intermittent starting problems | |||||||
71 Posts Member #: 316 Advanced Member Staffs |
9th Nov, 2008 at 07:41:00pm
This is driving me mad, no spark at the spark plugs, petrol is there. I have had this problem the last 2 weeks, been fine beforehand no problems. Weather may not be helping the situation.
9th Nov, 2008 at 07:49:47pm
Have you checked that the voltage to the coil is not going awol?
9th Nov, 2008 at 07:55:38pm
whats your battery like? if it goes with a jump but not after a run my advise would be to start by charging your battery fully.
10th Nov, 2008 at 10:22:56am
With a multimeter, tackle it logically.You said in your initial post that there was no spark,so check for voltage to and from the ignition switch and the coil,with some one pushing and pulling at the wires if necessary to see if there us an intermittent contact.If this all seems OK try putting the new parts that you mention on,one at a time, to see which one was giving the problem.If your battery is dodgy dont mess about, get a new one,but do check that the alternator is not at fault first, as above. |
11th Nov, 2008 at 06:02:52pm
Ok, my hubby has just sent me down the garden to post an update, thats the thanks I get for taking him a cup of tea.
11th Nov, 2008 at 06:07:36pm
hahaha classic!
11th Nov, 2008 at 06:53:01pm
Sorted, It was the starter motor, see my cup of tea helped loads.
