Home > Wanted > intercooler pipes
flyingturd
Member #: 4008
near cardiff np12
im after intercooler pipe what ya got
Kean
Member #: 341
aka T2clubby
South Staffs
You really need to be more specific to your requirements. Every intercooler installation is different and hence there is no "standard" pipe arrangement.
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
Figure out the way you want to route it and order a set or the right dia and bends!
flyingturd
Member #: 4008
near cardiff np12
i have a intercooler of a transit not sure the dia will check also want a bleed valve with pipes
flyingturd
Member #: 4008
near cardiff np12
ok the intercooler is 2" dia ends
ideally want 90's 45's and staights
tbh mate, its hard to help someone with so little info, have you tried the search button? i know theres only a dozen or so threads on this exact topic...
you can get 2" dia s/s dairy pipe quite cheap thats ideal for this imo, im gonna use these for the straights, and use the silicone bends you can get cheap off ebay
or you can do the above abd pay through the nose for lightwieght thinwall alloy pipe if your weight conscious
or you could use solid bends and long silicone straights, but i dont like this way
or you could get all metal pipe lengths and bend, and weld it all up
or you could get all metal tubes/bends and use silicone joiners
or you could go about it about a million other different ways, its a bit like hows longs a piece of string?
