Home > For Sale > Engine parts - new from machining 1380 ect
MK1dave62
Member #: 4317
North Yorks
hello due to recent circumstances i am selling my project engine. 1380 a series engine block at 73.5mm offset with cross-hatch hone, cylinder edge lip removed, decked face and checked for flatness, new cam bearings installed, centre crank cap machined to accept a centre main strap £120. crank has been reground at 0.10and balanced complete with new big end bearings, main bearings and thrust have been used in a dry build, crank tail is in exelent condition £120. majic wand gearbox reconditioned with 62 tooths differential 3.44 *missing casing* rubber yoke joints £100. mg metro large valve engine cylinder head, will require a clean £40. lightly modfied 12g940 porting work on inlets and exhausts, recut valve seats,skimmed and cleaned £70. shotblasted transfer housing £20. shotblasted clutch wok £10. preverto flywheel and backplate £30. also all bolts and oil filter housing ect avaliable if any interest. Never been run all parts as new
dave
Located in North Yorkshire most of the time. Can deliver anywhere in the UK at cost. Will take offers on the lot thanks
JordieNE
Member #: 1591
Prudhoe, Newcastle
Edited by JordieNE on 16th Nov, 2008.
MK1dave62
Member #: 4317
North Yorks
£400 for the lot? Anyone?
All the spares, spare diff, oil filter housings, nuts and bolts, timing chain covers and such
