Home > Help Needed / General Tech Chat > spark plugs
turboestate
Member #: 362
durham area
wonder if you guys can point me in the right direction as to which spark plugs i should be using.
love that straight cut scream!!!
______
/___|_____
_ (@)___(@)
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
for what engine spec?
alex
AlexF
turboestate
Member #: 362
durham area
1310 ...8.5 -1 cr....bout 1 bar boost
______
/___|_____
_ (@)___(@)
You'll get plenty of different opinions here. Some love NGK others Champion; no one likes both.
Personally I use NGK BPR8ES plugs, these are what are fitted to the Escort RS Turbo. They have a shrouded electrode and I've never had any problems.
Although it has to be said, they don't like getting wet with fuel.
Wil
jukka
Member #: 60
Forgotten more than most ever know
I use normal BP7ES plugs, quite satisfactory for normal road use. For lengthened period of full boost use I´d swap for 8´s. (For road use these are too cold IMO, easily dead with rich mixtures. Is applies to n/a engines as well)
TurboHarry
Member #: 115
Austria, near Vienna
I use NGK B8ECS (short ground electrode). Never fouled. Used warmer B7ECS before - never had problems.
Bimmer Twinky headed and turboed A-Series:
http://www.minifreunde.at/harry/projects.htm
giallofly
Member #: 164
The Stig..
Newport Pagnell
Never had a problem with NGK BP8ES's.
