| Home > Technical Chat > cleaning manifold | |||||||
174 Posts Member #: 781 Advanced Member Norway |
15th Nov, 2008 at 01:08:21pm
this is the way to go
15th Nov, 2008 at 03:40:44pm
I used to clean out two stroke exhausts the same way -the trick is not to let off on the compressed air until the inside has stopped burning or you will get blowback - and you dont want that ! |
16th Nov, 2008 at 12:15:27pm
if you want to clean carbon out of a manifold, or head etc then the best way ive found is to soak it in brake fluid over night. it really breaks up the carbon and makes it go all goey then pressure wash. no longer a series, but still 1.3 turbo.
16th Nov, 2008 at 12:23:49pm
I find it easiest just to chuck it in a bucket of caustic soda. Isambard Kingdom Brunel said:
16th Nov, 2008 at 09:36:56pm
Not if its aluminium you dont !! |
