Home > Help Needed / General Tech Chat > Pinion Spline Spec
pickmeup
Member #: 1200
Ive got a friend who is building an electric mini and utilising something similar to a mini gearbox for the final drive, however he needs the spline specification to what the pinion wheel is attached too and he alse requires the distance between the centre line of the pinion shaft to the centre of the diff! hes measures 4" but wants a propper measurement!
anyone got this info, i cant find it in any of my propper old austin books!
cheers, Gaz
pickmeup
Member #: 1200
anyone? i thought some of the gearbox gurus would be able to help?
I think most just buy these parts and fit them, no need to measure anything.
Looks like you will have to get the tape measure out :)
Edited by Sprocket on 22nd Nov, 2008.
I don't have this info - ad sprox says - it's not needed too often.
It should be easy to measure hovever?
pickmeup
Member #: 1200
im not too sure how to measure the spline , i might take one to work and stick it on the CMM and then find some specs! im sure BMC / rover must have realeased the info or i can get it from minispares? ive asked mini mag to ask keith calver and see if he has the info!
