| Home > Beginners Tech > fuel pump question | |||||||
280 Posts Member #: 4340 Senior Member sideways, Birmingham |
18th Nov, 2008 at 04:21:13pm
ok, my first ever question,
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol carl FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR" |
18th Nov, 2008 at 04:23:51pm
cavalier pump worked fine on mine . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
1050 Posts Member #: 764 Post Whore Staffordshire |
18th Nov, 2008 at 04:37:08pm
i would have thought it would be a good idea to double check the pressure of the reg output after the change, just in case. |
18th Nov, 2008 at 04:42:08pm
As above, but do NOT use the cavalier regulator - it will be set to fuel injection rail pressure, way higher than a metro turbo carb - just use the pump. Schrödinger's cat - so which one am I ??? |
20th Nov, 2008 at 07:57:00am
many thanks guys
