| Home > Beginners Tech > CR | |||||||
18th Nov, 2008 at 11:24:23pm
hello all only my second time of measuring the CR in my engine.... just wanted to see if this sounded about normal.
18th Nov, 2008 at 11:30:04pm
they look like they have been opened out abit to me. although my experience is limited.
Edited by James_H on 18th Nov, 2008. |
18th Nov, 2008 at 11:38:44pm
I used 2.7 for the gasket 18cc for the bores, and 25 cc for the head on a 1275cc engine and got 7.98:1??? I run a supercharger and I don't care the TB is on the wrong side.
18th Nov, 2008 at 11:48:31pm
what boost are you runnine?
19th Nov, 2008 at 07:20:52am
On 18th Nov, 2008 gr4h4m said:
I used 2.7 for the gasket 18cc for the bores, and 25 cc for the head on a 1275cc engine and got 7.98:1??? Asuming your 18cc is piston dish, ring land and deck height all measured together (which it will be if you did it with perspex over the top of the block), the maths is right (I got 7.96) but.... Three thoughts, a) having to fill the syringe 10 times to do a single measurement is hardly going to be accurate
b) doing the combined dish/ringland/deck on the block requires you to get TDC very accurately in the first place or the reading will be too large
c) some of the fluid (parafin?) can easily pass through the ring gaps while you are trying to get the measurement, esp. if you are spending a lot of time having to keep refilling the syringe, again, giving a reading too large
Edited by Rod S on 19th Nov, 2008. Schrödinger's cat - so which one am I ??? |
19th Nov, 2008 at 12:17:51pm
seems about right to me calculation wise
AlexF |
19th Nov, 2008 at 01:10:13pm
Sounds about right to me aswell, just a tad on the low side really unless you're going for silly boost? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
19th Nov, 2008 at 01:25:06pm
I'm with Rod on this some of the fluid has probably got past the rings,
19th Nov, 2008 at 08:36:54pm
thanks guys boots didn't have any.. whats the standard dish on the 1275?? am I close? I measured a 1.1mm from the bore to the top of the piston at tdc
20th Nov, 2008 at 08:42:38am
ok,
