| Home > Beginners Tech > Bore size | |||||||
69 Posts Member #: 2461 Advanced Member Portsmouth |
19th Nov, 2008 at 10:43:31am
19th Nov, 2008 at 11:29:58am
A .20 is 71.12mm. Add .20 to this and you get the finished bore... On 13th Jul, 2012 Ben H said:
19th Nov, 2008 at 11:32:56am
Is 20 thou half a mm? |
19th Nov, 2008 at 11:42:38am
Yes |
19th Nov, 2008 at 11:44:46am
On 19th Nov, 2008 T-shirt said:
Is 20 thou half a mm? Very nearly but not quite. Actually 0.508mm (or 0.51mm as would be commonly quoted) The spreadsheet from AFRacing gives the closest figures http://www.afracing.co.uk/CR.xls (right hand side of spreadsheet) Schrödinger's cat - so which one am I ??? |
19th Nov, 2008 at 12:36:03pm
Many thanks,
