Home > Help Needed / General Tech Chat > Budget Gauges
While the hot topic seems to be gauges I am on the lookout for some budget gauges.
Currently I have some magnolia clocks in my SPI which i wish to retain. I am going to fit a walnut dash with 3 52mm aux gauge holes.
I was thinking. PSI Boost Gauge (20 psi would be ideal), PSI Oil Pressure Gauge, and either an AFR Gauge or Oil Temp Gauge (recommendations???).
Does anyone know what gauges and fittings I could get which will not look a monkeys breakfast with my clocks and dash without spending the earth?
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
Sun pro ones are cheap and cheerfull enough
Thanks the Sunpro Styleline Gauges look pretty good.
I wonder if i could use their AFR gauge somehow?
ministef1
Member #: 1791
Cranleigh, surrey
and crap!!!! have a look on ebay.com and see if you can spot any autometer ones, i picked up a brand new water temp gauge for £14 bargain!!! and top quality!
"Cars are a lifetime of pain"
slater
Member #: 1291
Suffolk / Birmingham
Just get TIM gauges. Cheap and they work
auto meter arf gauge £30 in halfords..
AWDmoke
Member #: 713
Western Australia
Arf gauge? I think you mean
On 24th Dec, 2008 Nic said:
LOL!
Well i reckon i will get myself some reasonable-ish gauges.
boost, oil press, oil temp. and save for gav's afr/egr gauge etc. looks the mutts to me :)
I second that, the tim stuff i have had has been good.
with the AFR though i'g go for somthing WB with a good rep.
