Home > Wanted > Short Length of 2 1/8" OD Exhaust Pipe
Just need a short length of 2 1/8" or 54mm OD, 2" ID exhaust pipe to join a large bore LCB to a 2" downpipe. Mild or stainless will do.
If nobody has any, I'll get a long length from Merlin and keep it stock for TM members.
I might have a bit,
I'll check the size tonight.
actually scrub that,
the bit I have is 2.5" I just remembered i had to buy mild steel convertors to do mine.
Edited by Joe C on 20th Nov, 2008.
When I needed to do this I went to my local rude boy monstrosity exhaust centre. They have some of those pipe stretching gadgets that work with a windy gun, and so they stretched a short length about 6" of 2"OD stainless to make it 2" ID to use as a connector. Cost me £5 I think.
My solution was similar - when I bought all the stainless tubing, the company also could expand it out, they called it end forming.... so I had all the excess lengths "end formed" to 2" ID and cut them off to make the sleeves.
Just been using them this afternoon, see my build thread !
As Tom says, a "good" exhaust place should have the expanding tool.
edit, yes there is
Edited by Sprocket on 20th Nov, 2008.
http://cgi.ebay.co.uk/Exhaust-Pipe-Connect...Q2em118Q2el1247
*wink*
Thanks for the link Sprocket.
Merlin do list 2 1/8" pipe.
On 20th Nov, 2008 Sprocket said:
http://cgi.ebay.co.uk/Exhaust-Pipe-Connector-Sleeve-Joiner-Connectors_W0QQitemZ130268603897QQihZ003QQcategoryZ38786QQssPageNameZWD1VQQrdZ1QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
*wink*
I saw those when I was searching a month ago Sprocket.... but nothing to say they are stainless ?????
They are not, but does that really matter, unless you are looking for conrourse condition, *tongue* *wink*
Fair point....
I just decided I would make my final system out of stainless, even where bits weren't "off the shelf", more for life than looks.
My "intermediate" system is still mild steel at the very front *frown**frown*
might have some at work. i'll get the tape measure out tomorrow!
I think people are missing the point of that coupling. It will slacken off with two nuts and the linkpipe will slide out with no effort at all, no hammering now swinging on the silencer to breakit free *happy*
You've sold it to me.
It's the best solution I've seen so far.
i know the joints. got some of em at work, will see what sizes they are aswell.
I had to replace the rear section exhaust on the wifes car, Seat Arosa, it has one of these to join the front section to the rear. Granted after five years on the car I had to cut the bolts free, but once they were off, the rear section just slid out. I couldnt believe it after some of the pissing around I have done in tha past.
A couple of new bolts a little exhaust paste and its good as new.
I have one fitted to the manifold and linkpipe, as it was the easiest solution to the age old problem of fitting a 2" linkpipe to a "2 manifold
let me see the sizes of the ones at work paul. might be able to post one to you.
i have a set of expanders i can post if need be paul?
Make sure you wash out before you use them paul!!!!
Is this that place that has an escort van with something rediculous like 12 exhausts poking out of the back?
