| Home > Help Needed / General Tech Chat > Advice needed friends! | |||||||
166 Posts Member #: 221 Advanced Member |
7th Sep, 2004 at 02:13:25pm
Hey everyone, |
969 Posts Member #: 47 Post Whore Not very sunny swanage |
7th Sep, 2004 at 02:17:21pm
no idea what the actual problem or solutrion might be, but iirc the n/a gearboxes are the same apart from the final drive, (3.2 rather than 3.44 usually) and the nose bearing, which is bigger on the turbo. that said, you could quite easily use the casing from the turbo, and the rest from the mg
And on the 7th day........... God created turbochargers! |
47 Posts Member #: 329 Member |
7th Sep, 2004 at 04:31:38pm
I may be stating the obvious here but are your engine mounts in good order or have you solidly mounted the rod change unit cause either can cause the gear lever to either disengage or prevent full engagement of gears. |
7th Sep, 2004 at 06:52:20pm
Thats what my initial thoughts were Justin, but I was told if I was able to select 1 gear successfully I should be able to work them all. All the engines mounts were new, I did how ever change the rear mounts to the solid type, but I was assured that this was'nt the cause. When the clutch is in, it defo seems to engage 4 th gear.
Edited by 1380Turboman on 7th Sep, 2004. |
244 Posts Member #: 34 Senior Member |
7th Sep, 2004 at 09:22:42pm
Mini gearboxes aren't that hard to re-build, if you take your time and examine all parts carefully. The haynes manual explains it quite well.
Edited by Gibbo on 7th Sep, 2004. |
