Home > General Chat > Help with engine spec
Jackman
Member #: 984
Westhoughton, Bolton
Right this is the first turbo engine ive gone to spec up. Its not in full detail as its not mine so i dont know how much he is willing to spend on the engine.
1380 a+ block
Omega pistons, 11cc dish
25cc fast road head Exhaust. 29.4mm Inlet. 35.6mm
Mspd ph 2 cam
Metro T3
Standard crank and rods
Lightened fly and backplate
Grey pressure plate
Minispares x-pin diff
SC drops
Standard gears
BK450 Gasket
Standard rockers
Megajolt setup
Intercooler
I know there is a turbo oil pump and other things like that required.
With this spec i get a estimate of 8.5cr, i know he wants to run between 15 and 18psi with the possibility of more in the future.
Any suggestions or recomendations on this?
Thanks
Jackman
Edited by Jackman on 20th Nov, 2008.
Manchester Minis
Sam
Member #: 1686
Oxford
That collection of parts seems reasonable.
One thing that sprang to mind is the porting on the head, how big were the ports made?
I would get the crank tuftrided and balanced and get the rods polished to remove any possible fracture points.
I’m concerned by the lack of auxiliaries mentioned.
My main points of concern within that are:
Turbo I would put a 360 degree thrust bearing in for more support and maybe change
What about cooling?
Intercooler has been mentioned, what intercooler has your friend decided on?
OMG Robert that's a big one
Isn't the Mspd Ph2 camshaft a fast road one? This is not the same as the Avonbar ph2.
I recon the Kent 274SP for that engine *wink*
the CR IS WAY TO HIGH 9.25:1
you wont get past 11 psi of boost there without detonation on nearly
18cc accralites ar NLA Unless you commission a set of 5 and a 9 week lead time
i would opt for a 1293 engine and 10 cc omegas cast at £270 but.... forged if you budget will allow and 28 cc in the head, this would give you a CR of 8.38:1 more like it
its simpley piston avalability with the right cc in the crown.
i managed last week to get some accralites last of stock +40s 14 cc dish forged.
but there are many permutatios in pistons its if you want to machine them out etc..........
cam chioce in my book phase 2, kent 266 or mg cam the chioce is yours
Edited by BENROSS on 20th Nov, 2008.
Sam
Member #: 1686
Oxford
I got 8.6 steve, ill get back to you about that gearbox in the new year.
Jackman
Member #: 984
Sam - ill most prob get him to get a benross head so will be those port sizes. As for auxiliaries ill have a more in depth spec when i get to talk to him fully and find out how much he will spend on it.
Cooling, most prob a 2 core rad, intercooler i cant say at the moment as i havent spoke to him about that either.
V - Is the avonbar the better option on the cam?
Sprox - Its not my engine but ill let that cam choice be known too.
Benross - i get 8.5/8.6 on that spec, have i done somthing wrong caluclating it?
Thanks everyone.
Manchester Minis
With 11 cc pistons and 25cc chambers with a 1380 I get more like 9.9:1!! How have you calculated it?
You need another 7 cc from somewhere to get 8.5:1.
the Avonbar PH2 cam would be my choice for this engine too.
Similar spec to the engine I'm currently building.
I think that this may be a good alternative to the Avonbar Ph2.
Trouble is Kent do not quote the scatter in the timing figures on their website. I'm looking for a cam that brings forward the inlet timing on the inner cylinders.
wil-h
sweptt 345cc
unswept
head volume 25 cc
piston dish 11cc
head gasket bk450 3.8cc
ring lands 2cc
total 41.8cc
calcs to 9.25:1
Coupe
Member #: 2178
Leyland, Lancs
Thats assuming the piston crown is dead level with the deck face though isn't it?
There are a lot of assumptions here.
I use slightly different figures to steve (gasket 2.5cc and I ignore ring land). Hence why my figure looks higher.
This of course means that in reality my CR is lower than calculated. But this ia a safety margine I can cope with. also as I only ever build 998s the ring land volume really is bugger all.
Jackman
Member #: 984
Bore 73.5mm
Stroke 81.4mm
Compression Ratio 8.58:1
Gasket Volume 3.80cc
Ring land Volume 0.5cc
Piston Volume 11.00cc
Head Chamber Volume 25cc
Deck Volume 5.25cc
Thats how i worked it out, i used the values from the AF racings calculator using the standard 1275 values for a few.
I think the best idea is go for the 11cc pistons and then work out the head cc required when i find out the deck volume and other things.
Thanks alot for the help so far *happy*
Manchester Minis
Sam
Member #: 1686
Oxford
swept of 344
unswept of 45
so unswept+swept=390
390/45= 8.6.
Agree, 8.58 from those figures.....
Is your deck volume actually going to be 5.25cc though ???
Mine was 1.8cc when I actually measured it (depth micrometer to top edge of piston with DTI to ensure true TDC, then maths; pi * (d^2)/4 * depth )
Of the aftermarket pistons I have fitted, they have all been about 40 thou down the bore, that includes Megas and Omegas
40 thou=a fookin mile.
yes it is, but it at least alows you to decide how to engineer your compression ratio, which I think is the main reason for it.
I had to take 20thou of the top of jackmans block to keep the compression ratio the same as standard.
40thou is around 5cc
Edited by Sprocket on 22nd Nov, 2008.
Yep, mine were 14thou down for 1.8cc so the maths is about right...
