| Home > Help Needed / General Tech Chat > Help with SU Setup (Na) | |||||||
22nd Nov, 2008 at 07:59:28pm
After being plagued by numerous electrical problems, Ive just got my british open classic running for the first time in about 4 years!!
22nd Nov, 2008 at 08:50:10pm
Joe how have you tested the timing that sounds alot like a retarded ignition to me On 17th Feb, 2009 Rob H said:
22nd Nov, 2008 at 09:00:23pm
i marked the block/dizzy years ago, ill check with the light tomorrow, but that shouldnt be an issue "Turbo's make torque, and torque makes fun"
22nd Nov, 2008 at 09:12:19pm
Actually thinking back, when i killed it before coming home for tea it did run on for about 10 seconds...ill get the gun on it tomorrow morning "Turbo's make torque, and torque makes fun"
22nd Nov, 2008 at 10:37:30pm
That could have been caused by the high idel speed and hot EVT On 17th Feb, 2009 Rob H said:
23rd Nov, 2008 at 12:55:04pm
On 22nd Nov, 2008 joeybaby83 said:
Actually thinking back, when i killed it before coming home for tea it did run on for about 10 seconds...ill get the gun on it tomorrow morning o/t does retarded timing cause this?? i think my clubby has retarded timing for while now, runs on a fair bit to lol im off to check :) witch type of carb is it?, there is a couple of how to set-ups in Haynes manual used it a couple of time works well:) Yes i moved to the darkside |
23rd Nov, 2008 at 05:11:31pm
it was a fair way out, about -4 degrees at 1200 rpm lol
23rd Nov, 2008 at 05:28:47pm
8th Dec, 2008 at 12:02:24am
Righto, bled the brakes on the british open classic, and took it out for a blast tonight, surprisingly nothing fell off it drove and braked in a straight line haha
8th Dec, 2008 at 12:04:53am
around 13:1 should be pretty good is what ive heard...
8th Dec, 2008 at 12:18:50am
thats for best power i think? on cruise shoudl i not be aiming for stoic (15 ish) or leaner? maybe 16/17?
8th Dec, 2008 at 12:23:25am
what sort of afrs do stad engines run? "Turbo's make torque, and torque makes fun"
8th Dec, 2008 at 12:52:26am
im hitting google!
Edited by James_H on 8th Dec, 2008. |
26th Dec, 2008 at 08:52:08pm
right, bit of an update
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
26th Dec, 2008 at 08:58:07pm
i had something similar...have you tried driving without the vac advance connected...the module on the side of the dizzy may be knackered. On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
26th Dec, 2008 at 08:59:07pm
Obvious question, but is your wideband reading right ???
26th Dec, 2008 at 09:08:34pm
the widebands fine, its an aem one and been using it on other cars
26th Dec, 2008 at 09:37:56pm
just been having a gander at this:
Edited by joeybaby83 on 26th Dec, 2008. "Turbo's make torque, and torque makes fun"
27th Dec, 2008 at 08:09:27am
Sounds about right, this is from about two weeks ago (in my MS trials thread)
Edited by Rod S on 27th Dec, 2008. Schrödinger's cat - so which one am I ??? |
27th Dec, 2008 at 05:48:19pm
ha, set the jet 50 thou down from the bridge, (wasnt far from this anyhow) and bosh, like magic the thing purred away like a kitten @ 900 rpm and 14.7:1 afr
Edited by joeybaby83 on 27th Dec, 2008. "Turbo's make torque, and torque makes fun"
27th Dec, 2008 at 07:08:00pm
