| Home > Help Needed / General Tech Chat > Steering Problem. | |||||||
![]() 862 Posts Member #: 1660 Formally Mini_Uk London |
23rd Nov, 2008 at 01:02:04am
Hi lads.
Shit Happen's |
271 Posts Member #: 1844 Senior Member BURNTWOOD, staffordshire |
23rd Nov, 2008 at 08:24:20am
hello
23rd Nov, 2008 at 09:09:50am
I have done the same as Alan above BUT only as a very temporary measure.
23rd Nov, 2008 at 12:35:22pm
Think i'll do that for the time being, up till christmas, then try get a good 2nd hand colum hopefuly.
Shit Happen's |
23rd Nov, 2008 at 12:43:05pm
On 23rd Nov, 2008 Markie_D said:
can you buy a new pinion ? Cheers. Don't know - I still have second hand stuff I use... The fact your mate already replaced the column once, and it failed again, suggests either the column/rack is badly mis-aligned, or it's the splines on the rack spindle that are shot, not the column. Hopefully for you, just mis-alignment..... Check it out carefully. Schrödinger's cat - so which one am I ??? |
23rd Nov, 2008 at 01:53:46pm
can you buy a new pinion ? Cheers. Don't know - I still have second hand stuff I use... The fact your mate already replaced the column once, and it failed again, suggests either the column/rack is badly mis-aligned, or it's the splines on the rack spindle that are shot, not the column. Hopefully for you, just mis-alignment..... Check it out carefully. Going to go to the garage now and have a good look. only thing i didn't touch when building the car back up was the rack and colum. got my haynes with the diagram, so should be fine :) Cheers anyway lads. i'll let you know what it was. Shit Happen's |
28th Nov, 2008 at 10:23:26pm
As i said before, my car is 1980 1275GT.
Edited by Markie_D on 28th Nov, 2008. Shit Happen's |
28th Nov, 2008 at 10:31:22pm
The sponge thing is the bottom felt bush. You can get new columns from minits for a good price, about 40 quid IIRC.
28th Nov, 2008 at 10:38:18pm
you loosen the rack before fitting the column to make sure the spigot on the rack and the column are straight onto each other otherwise they will wear out like what has happened to yours. |
28th Nov, 2008 at 10:38:56pm
As above, you MUST loosen the rack while bolting up the column to rack joint...
28th Nov, 2008 at 10:55:18pm
Got ya..
Shit Happen's |
so as i was near work, i got my mate to look at it. he ended up putting a good nick 2nd hand steering colum on, as a new one is near £200, seeing it's a 1980 mini. the pling thing on the rack had worn. all was fine after that, till a good few months later, which was today, the samething happens. till i got time to have a look at it my self, what would you say the problem could be to why it has happend again ?
