| Home > Help Needed / General Tech Chat > Camshaft endfloat | |||||||
![]() 552 Posts Member #: 300 Post Whore Cumbria |
7th Sep, 2004 at 08:15:55pm
Anyone built an engine and had lots of the above? Here for the craic..
![]() 4 Posts Member #: 355 Junior Member |
7th Sep, 2004 at 09:01:02pm
Thought you machined material off the back of the cam timing gear to get endfloat in? |
7th Sep, 2004 at 09:05:12pm
Maybe your triangle piece that helps hold the cam in place is worn. as this would make the end flow bigger. Best 1/4 mile 13.2 seconds @116 mph
244 Posts Member #: 34 Senior Member |
7th Sep, 2004 at 09:31:00pm
Not suposed to shim the cam, sometime a new triangle piece works but most of the time you need to machine the cam gear.
146 Posts Member #: 350 Turboing minis since '89 Supercharging minis since '04 |
7th Sep, 2004 at 09:52:07pm
i take it your are taking the measurement with the timing gear on and torqued ? the free play should be between the gear and triangle plate
8th Sep, 2004 at 01:03:52am
i noticed this when i was building up my 1380, wasnt until i put on the timing gear torqued it up etc that i realised that the triangle controols the end float. realy shouldnt be that big! the gap the triangle sits in isnt even 3mm wide...
8th Sep, 2004 at 06:01:34am
Once the cam gear is torqued up the endfloat should be less than 1 mm. Had once a cam gear that did not provide any endfloat just the oppiseite, the cam would not rotate... |
9th Sep, 2004 at 12:29:54am
Cheers all Here for the craic..
9th Sep, 2004 at 07:34:48am
Cant you just turn those plates round and use the other side?
9th Sep, 2004 at 11:40:32am
NOOOOOOOOOOOOOOOOOOOOO!!!
9th Sep, 2004 at 11:47:57am
it's just a plate isn't it?
9th Sep, 2004 at 04:08:37pm
be a bit daft to only have bearign material on one side, as a moveing face buts up agains both sides. turbo 16v k-series 11.9@118.9 :)
![]() 136 Posts Member #: 5193 Advanced Member Dunstable |
15th Feb, 2010 at 10:08:15pm
going on from this im just building up my engine with a phase 2 turbo cam which is new from avon bar and a new triangle i have .6mm endfloat and the limit in the book is .178mm i havent yet put the cam gear on but im a bit worried as to why i am getting this much endfloat ? |
15th Feb, 2010 at 10:11:31pm
because you havent got the cam gear on.
15th Feb, 2010 at 10:11:40pm
Put the cam gear on and tighten the nut THEN check the end float and post back with the results On 26th Oct, 2004 TurboDave16v said:
15th Feb, 2010 at 11:00:26pm
Whey i have to officially say the haynes manual is absolutely useless in the way it shows how to do it, thanks sprocket and mini13 for responding just got to put the casings on now
16th Feb, 2010 at 03:41:39pm
Yeah I cant remember the number of times I've checked the end float - been horrified - then remembered to put the timing gear on LOL AlexF |
16th Feb, 2010 at 03:45:00pm
I did exactly this just last week. Mind you even with the timing gear on it was on the limit. http://www.twin-turbo.co.uk
16th Feb, 2010 at 05:19:23pm
Does it make that much difference?
AlexF |
16th Feb, 2010 at 05:44:51pm
I've also done this in my younger days of knowing no better.
16th Feb, 2010 at 06:08:12pm
On 16th Feb, 2010 AlexF2003 said:
There isnt a reason for the side loading of the cam is there? Yes there is, which is why the triangle plate has whitemetal on one side only (the loaded side) and cannot be reversed without deliberately elongating one of its holes. The dizzy drive is helical. Not much of a side load but just enough to keep the cam floating in one direction. Schrödinger's cat - so which one am I ??? |
16th Feb, 2010 at 06:22:52pm
16th Feb, 2010 at 06:40:04pm
On 16th Feb, 2010 Sprocket said:
Whats a dizzy drive? ![]() What they had back in the 50's when they designed it
So they knew they had a very small thrust in one direction and designed the plate accordingly :) Schrödinger's cat - so which one am I ??? |
