| Home > Help Needed / General Tech Chat > 3rd Motion shaft | |||||||
25th Nov, 2008 at 11:08:57pm
Hellos, how do you get the top hat off your 3rd motion shaft? I take it it's just a press fit? Can heat be used? Mine is being difficult, although not as difficult as my computer as the key board won't work properly! Thanks! On 7th Nov, 2008 Nic said:
26th Nov, 2008 at 06:50:08am
gently lever of with big screw driver, i take it you mean the 1st gear bearing gernal always looking for them bigger bunches of bannanas |
26th Nov, 2008 at 07:40:10am
Yes that's the one, the first gear runs on it and it hold the syncro in place. I guess some more gentle persuasion is needed. Thanks Hoggy. On 7th Nov, 2008 Nic said:
