| Home > Help Needed / General Tech Chat > expected power | |||||||
![]() 514 Posts Member #: 2104 Post Whore Essex - UK |
5th Dec, 2008 at 10:39:41am
i am currently running the following med engine
"Tuning should be a compromise between what is possible and what is necessary"
![]() 184 Posts Member #: 346 Advanced Member Portsmouth |
5th Dec, 2008 at 10:49:28am
Sounds low for 12psi?
1310cc TWINK - T Conversion |
5th Dec, 2008 at 10:50:59am
106 at the wheels seems ok. 12psi should easily net over 140bhp at the fly with the right head, cam aind IC. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
5th Dec, 2008 at 11:11:04am
Which rolling road?
In the 13's at last!.. Just |
5th Dec, 2008 at 11:13:28am
ATSPEED near southend the guys in there are realy friendly and helpfull
5th Dec, 2008 at 01:26:25pm
You should have more than that. We've seen 150hp at the flywheel from 10psi.
5th Dec, 2008 at 01:48:09pm
right so is it a case of getting it down the front or do you recon it would be ok with getting some cowling on it to duct the air up to it as im trying to keep everything contained in the engine bay hidden
Edited by turbominij on 5th Dec, 2008. "Tuning should be a compromise between what is possible and what is necessary"
5th Dec, 2008 at 02:07:16pm
You should be able to get intake temps down to around 20 degrees C this time of year.
5th Dec, 2008 at 04:58:31pm
is the gear box straight cut or Helical On 17th Feb, 2009 Rob H said:
5th Dec, 2008 at 06:13:37pm
my guess that the head is standard
5th Dec, 2008 at 07:32:17pm
the head is as flollows quoted from the med website
Fitted with our Gold quality 1.5 roller tip rockers, ARP 11 stud head kit and F.I.S. head with special non squish combustion chambers with 29.0cc for low compression, with 36.0 and 30.0 plasma nitrided valves with waisted stems and 3 angle valve seats to maximize air flow, alloy bronze guides with special tapers, ports fully modified with full valve guide boss removal and extra detail to the exhaust ports for extra flow. Lead free inserts fitted for the use with unleaded fuel and dual rate double valve springs http://www.med-engineering.co.uk/product_d...58&vlang_id=202 the gearbox is a helical with cross pin diff "Tuning should be a compromise between what is possible and what is necessary"
6th Dec, 2008 at 08:18:36am
personaly i would nt put any more power through the standard box,
6th Dec, 2008 at 05:08:21pm
i personnally think that the figure means fuck all, no rolling roads are the same, if your happy with how it drives and your confident that its been set up "safe" that is whats important imo.
6th Dec, 2008 at 05:17:17pm
On 6th Dec, 2008 Carl said:
i personnally think that the figure means fuck all, no rolling roads are the same, if your happy with how it drives and your confident that its been set up "safe" that is whats important imo. That's why we use 'bananas' instead of BHP on TM. As long as the losses are measured at the RR the flywheel figure is just as 'accurate' as at the wheels. And unless you know the losses the wheel figure is pretty pointless IMO. we all have a feel for what an engine should make, but estimating losses is just a guess (one flat tyre can cause massive losses). This engine should make in excess of 140bhp, but what that translates to at the wheels is unknown. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
