Home > Technical Chat > standard engine steadies, top and boottom,
does anyone have both of these off the car that they could measure the bores and width of the rubber bush housings for me please, i do have folk looking into it but i could do with the dims as soons s possible,
much appreciated.
carl
t3gav
Member #: 229
Gavin@minispares.com
kent
25.6mm diameter, 29.3mm wide
t3gav
Member #: 229
kent
That's the measurements for a poly bush kit if that helps.
Is that for both types,?
not the bushes Gavin, i need the actual bore sizes.,
t3gav
Member #: 229
kent
The bushes fit top and bottom if that's what you mean?
t3gav
Member #: 229
kent
25.6 diameter, 21mm wide. For the top one anyway
the lower one on the clutch housing,
are those dims actual bore sizes from the steadies,
carl
t3gav
Member #: 229
kent
Yes that is the bore size and width of the top steady.
thanks , that'll do,
Wow, that's almost an inch!
