| Home > General Chat > Rover V8 / hydraulic tappet experience or knowledge? | |||||||
8th Dec, 2008 at 05:48:55pm
Despite having had three range rovers, and an SD1 vitesse, I've never had any problems with hydraulic tappets.
Edited by turbodave16v on 8th Dec, 2008. On 17th Nov, 2014 Tom Fenton said:
8th Dec, 2008 at 06:04:53pm
Weeeell,
![]() 6965 Posts Member #: 507 Fastest A Series Mini in the World leeds/wakefield. |
8th Dec, 2008 at 06:09:47pm
CVH's , do they still uise them,
8th Dec, 2008 at 06:12:35pm
Might be worth pulling the rocker cover and checking the preload on the lifter.
8th Dec, 2008 at 07:18:09pm
It isn't a crack in an exhaust manifold is it?
8th Dec, 2008 at 07:25:12pm
Most definately not - I wish it was. It's a metallic clack! On 17th Nov, 2014 Tom Fenton said:
8th Dec, 2008 at 07:32:10pm
Are they like CVH? Whip them out, squeeze them in a vice so all the crap comes out......then throw them back in with a drop of decent oil. 9 times out of 10 used to quiet them down On 19th Jan, 2010 wil_h said:
8th Dec, 2008 at 08:42:33pm
big end bearings can rattle away for weeks long as you dont rev it hard. seen it 1st hand. but the dont randomly get quieter. quck n simple test i find is to inspect the dipstick, if it has a very fine grey/almost black powwder on it its the babbitt material from the bearing thats lunching itself, most noticable whn you wipe a bit of the dipstick with your finger. can usually use this technique to see a big end bearing failure before it even starts to make a noise! . see the grey shit and a few weeks later the bottom end is rattling. can you not take the rocker covers off easily and inspect the clerances, if any are notably excessive compared to the others that highlights your duff lifter. turbo 16v k-series 11.9@118.9 :)
8th Dec, 2008 at 09:07:10pm
I will have the covers off soon. This is the Bosch engine though - i have to take off the upper intake and all the EGR crap just to get at the rocker boxes... On 17th Nov, 2014 Tom Fenton said:
![]() 6752 Posts Member #: 828 Post Whore uranus |
8th Dec, 2008 at 10:07:00pm
something you might find dave is the tappet on the lobe has not been rotating ,and it wears a rectangular wear patch on it ,this then takes up the tappet compression and starts to rattle ,then ,if the tappet starts to rotate again , it will take up the clearance as it rotates and stop tapping then go loose again and make noise .if it has been going quiet ,then loud id deff look at a tappet ,and id hoick em out and change them all ,have a good look at the lobes and see if they are domed acrosss the face on max lift .also id drive it for a while and get it well hot with the new oil for a few 100 miles ,oh and hows the oil pressure ?
Edited by robert on 8th Dec, 2008. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
703 Posts Member #: 105 1st to provide proof of a running Bimmy Conversion! Brisbane ,Australia |
9th Dec, 2008 at 03:57:15am
Probly a cracked piston www.miniman.com.au
