| Home > Help Needed / General Tech Chat > Plumbing in Water Cooled Turbo's | |||||||
10th Sep, 2004 at 10:13:47pm
I was thinking plumbing it in off the heater take off, but... |
10th Sep, 2004 at 11:19:57pm
You need to use a bit of 'nouse' and put together somethign to do the job... The unions on the T2 water cooling are 10mm dia - and 10mm copper pipe is available from plumbers, as are reducers from the commonly available (15mm???) tube size... So all you need to do is knock somet up...
11th Sep, 2004 at 11:49:32pm
I dont even have the unions, spose i had better head down the local pirtec pipe maker |
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
12th Sep, 2004 at 04:14:59pm
i might have some spare unions, i'll have a look later! |
12th Sep, 2004 at 07:29:28pm
TD how did the turbo recieve its water flow then? as water isnt "pumped" throught the botom hose. or am i missing something! turbo 16v k-series 11.9@118.9 :)
12th Sep, 2004 at 10:40:43pm
ok very briefly because im in a rush...
12th Sep, 2004 at 10:49:55pm
Cheers for that - it all makes good sense, the only thing is ......
12th Sep, 2004 at 10:58:44pm
damn i havent posted anypictures of this on tinternet and my mums computer is so old it doesnt have usb!!! i cant post any pictures till friday, sorry
13th Sep, 2004 at 04:54:06pm
Where els3e would you suggest? It is compromised however you do it, but basically connecting it in parralel with the rad is supposedly ideal in these instances On 17th Nov, 2014 Tom Fenton said:
18th Sep, 2004 at 02:08:26am
ok some piccys are up on my unfinished mirage fitting pics, http://www.netsnapshot.com/pcw/buildalbum-...T=13975&KEY="3"
18th Sep, 2004 at 03:17:23am
i would have thought anywhere else that recieved flow from the pump would be beter, for example, ou tthe head tapping (heater takeoff) through turbo, through matrix(or extra radiator) into bottom pipe of rad.
18th Sep, 2004 at 07:55:29am
well that's the way i had mine plumbed for many years - but in order to get more heat (flow) out of the far end of the head, i changed it slightly - basically adding a larger connection from heater tap point straight to the top hose. I then Tee'd into this pipe, the pipe going through the turbo and into the bottom hose.... On 17th Nov, 2014 Tom Fenton said:
