| Home > Beginners Tech > Head and Compresion Ratio Questions | |||||||
9th Dec, 2008 at 06:50:13pm
Hi
9th Dec, 2008 at 07:09:00pm
It seems like your basic problem is you are starting with a specification for a high performance Normally Aspirated engine.
9th Dec, 2008 at 07:14:57pm
You're right about the engine. Came out of an ebay scrapper, so I'm working with what I've got.
9th Dec, 2008 at 07:35:13pm
On 9th Dec, 2008 apbellamy said:
Would it be easier to use the CD & siringe method to measure everything in the block in one go, then add the head and gasket to that? Yes, BUT you have to me mindfull that some of the paraffin (or whatever you are using) will leak past the ring gaps so, You either have to do it quickly (a proper burette, not syringes...) Or, pack some grease down the sides of the pistons first - this will stop the ring land volume being measured but it is usually very small. ALSO, if doing the dish/deck height in situ, it is ESSENTIAL to have an accurate TDC position. :) Schrödinger's cat - so which one am I ??? |
9th Dec, 2008 at 09:06:26pm
So... the pre-A plus 1380 that's sat in my shed might be a better option then??
9th Dec, 2008 at 09:25:32pm
wont the pistons be larger that 6cc dish if they are standard? my 998s were 6cc I run a supercharger and I don't care the TB is on the wrong side.
9th Dec, 2008 at 09:30:09pm
So... the pre-A plus 1380 that's sat in my shed might be a better option then?? From memory, it has a fair deck height, a 73.5mm bore, pistons with a 6cc dish. Some quick maths with measurements from memory on AR's spread sheet gave it a CR in the mid 9s with my stage 3 head as it is. I would have to loose the Kent 286 cam, but that's not really a big deal. And it would mean I would get the light weight pre-verto crutch too. Well, same skimmed head, and LESS dish in the pistons should mean an even higher CR. If there is some deck height it would help, BUT it's a much bigger capacity (1380cc you say) so the CR goes up yet again for the same chamber/piston dish volume..... This sounds even worse..... Schrödinger's cat - so which one am I ??? |
9th Dec, 2008 at 10:15:38pm
I need to dig it out tomorrow and do some proper measurements, as the ones I've based my calcs on are from memory and I haven't really touched it for a year.
9th Dec, 2008 at 10:41:18pm
i calc it up to 10.85:1 way too high,
Edited by BENROSS on 9th Dec, 2008.
10th Dec, 2008 at 07:55:26am
I'll get the engine out tonight and do some measuring. From memory the head that I took of it had had a lot of meat taken of the face, which (in my mind) implies that the engine had quite low comp to start as it came out of a n/a grass tracking car. Edited by apbellamy on 10th Dec, 2008. On 11th Feb, 2015 robert said:
10th Dec, 2008 at 09:06:30am
It was a hill climb car that it came out of Andy. If something is worth doing, it's worth doing half of. |
10th Dec, 2008 at 09:15:13am
On 10th Dec, 2008 minimadmotorman said:
It was a hill climb car that it came out of Andy. On 11th Feb, 2015 robert said:
10th Dec, 2008 at 06:25:12pm
I've dragged the 1380 out of the shed and done some rough measuring. Again, CR's are worked out using AF's spread sheet.
11th Dec, 2008 at 08:54:57pm
I've been over to John's house and measured his engine. It's a standard bore with the pistons flush to the top of the block. The pistons have a 13.1cc which makes a compresion ratio of 9.4:1.
