Home > For Sale > 998 engine.
shane
Member #: 1246
Lowestoft, Suffolk.
Firstly sorry for my firsrt post in ages being in the for sale section, I have had no spare time to use the forum as all my spare time has been swallowed by my house.
Right, due to loosing storage facilities I have to get rid of a few bits, first to go is the tuned 998 I was running in my mini prior to the turbo conversion.
Spec.
998cc bottom end balanced crank, rods, clutch, and front pully.
Flat top pistons
Pockets machiened in deck for 1275 head
SW5 cam
duplex timing gear
Metro turbo head, ported and polished, 10.5:1 CR
Aldon yellow dizzy
maniflow inlet manifolds
Twin HS2 carbs with K&N's
Cooper free flow exhaust manifold
Box converted for close ratio gear set, centre pic up, hardened diff pin, 3.44:1 FD
Lightened and balenced verto clutch and flywheel.
Milage is no more than 4k, all work done by scholar engines.
Produces 65 nana's (bhp)
With lower Cr believe would be a good base for a 998 turbo motor
Engine needs a gasket set as it has a few oil weeps, (Tming cover and rubber half moon to box)
Also a fresh friction plate as the one fitted slips occaisionally when driven hard.
Looking for £650 but am open to sensible offers, or if there is enough interest, I will concider breaking.Cheers
Shane
Edited by shane on 12th Dec, 2008.
pickmeup
Member #: 1200
hi shane Pm me your number! im deffo interested in the engine although i have a new set of twin carbs and a head already, cheers gaz
shane
Member #: 1246
Lowestoft, Suffolk.
Pm sent
Shane
