Home > Help Needed / General Tech Chat > Megajolt Question - Doing Crazy things
Bought an MJLJ for a mate wired it all up and connected it to laptop fine, i havent got it connected to car or anything, but the rev gauge jumps up and down speradically. Only very breifly then goes back to nothing???
Any Ideas.
miniboo
Member #: 2253
Las Vegas, Brit in the States
is it an external rev counter?
No its the Rev Counter within the MJLJ software.
The MJLJ isnt even on the car yet.
I have the same with my standard clocks and MJ. Have a search as there was some suggestions on a solution to this using the PIP signal.
miniboo
Member #: 2253
yeah but if its the one in the software PIP wont help.
I would wait until it is plumbed in the car and see what happens then.
Pretty sure that a megasquirt/megajolt will do this with nothing connected to it.
Have you got an EDIS connected to the MJ?
Yes, The Edis is connected, So is the coil pack so is the sensor. All i wanted to do was test the Connection to the lappy and test the Map Sensor.
But when the MJ is just sat there it keeps putting Revs on?
Crazy shit
Anymore Takers on this??
Just to add to this, i figured out why that mjlj was going crazy, i was powering the mj with a battery charger. I powered with a normal battery and it worked fine.
Chargers must give off dodgy signals or summat?
dickhead,lol
I know haha
philc
Member #: 1346
bromsgrove
Any Ideas.
mine does this on the laptop, i have to shut the screen down and open again and its fine, going to change the vr sensor to see if that sorts it
