Home > Help Needed / General Tech Chat > Air temp gauge/sensor
G13B
Member #: 1376
Looking for a air temp gauge and sensor, ideal would be 2 small lcd panel showing the heat in celsius. Will fit 2 in my plenum.
Have found nordskog ones about $75 a piece, but maybe there is a cheaper and equaly good solution out there?
cheers
//marcus
G13B
Member #: 1376
Have found one, even better i can go there and have a look at it before i decide. 2 type k probes is supplied, does 2 temps and if you want you can have it show the difference between them, suits my fine
8-)
Heres a pic of the ugly f***er:
DVM1322 – DIGITAL THERMOMETER (in english)
http://www.kjell.com/filarkiv/SUPPORTPDF/4...48183/48183.pdf
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=10718
Or you can buy the thermocouples seperately in the link you posted in the uk from somewhere called maplin for about £6.
I used one in my car for a while
G13B
Member #: 1376
Thanks Nic!
Looks just like the unit i had in my fantasy, one color lcd for pre ic core and one for after…is there any higher deg ones out there? Think 70C is maybe a tad to little to use straight after sc outlet?
many thanks!
//marcus
